Atmel SAM3 RTOS Demo
This page documents the Atmel Studio 6 IDE RTOS demo application
that runs on both the SAM3S and
SAM3X ARM Cortex-M3 microcontrollers
from Atmel. The demo
uses the FreeRTOS GCC ARM Cortex-M3 port, and components
of the comprehensive Atmel Software Framework
(ASF).
Two pre-configured projects are provided. One runs on the SAM3S-EK2 evaluation
kit, and the other on the SAM3X-EK evaluation kit.
IMPORTANT! Notes on using the FreeRTOS SAM3 demo projects
- Source Code Organisation
- The Demo Application
For convenience of distribution, the official FreeRTOS zip file download
includes source code files for all the RTOS ports, and all the RTOS demo
applications. The projects presented on this page only need a small subset of
these files. See the Source Code Organization
new project.
The Atmel Studio 6 Solution file for the ATSAM3S-EK2 demo application is called
RTOSDemo.atsln, and is located in the FreeRTOS/Demo/CORTEX_ATSAM3S-EK2_Atmel_Studio
directory.
The Atmel Studio 6 Solution file for the ATSAM3X-EK demo application is also called
RTOSDemo.atsln, and is located in the FreeRTOS/Demo/CORTEX_ATSAM3X_Atmel_Studio
directory.
The Preparing the Project Directory Structure section
of this page contains important information on preparing this directory.
The Atmel Studio ARM Cortex-M3 Demo Application
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0 (see the functionality section
below), then the demo will include the standard com test tasks. The standard
demo com test creates two tasks - a Tx task that sends characters to the USART,
and an Rx task that expects to receive every character sent by the Tx task. A
loopback connector is required on the USART port for this mechanism to work - simply
link pin 2 to pin 3 on the 9 way connector marked "USART" on the
SAM3S-EK2 and SAM3X-EK hardware.
It should be noted that the com test tasks are included to demonstrate queues
being used to communicate between tasks and interrupts, and to demonstrate a
context switch being performed from inside an interrupt service routine. The
serial driver used is not intended to represent an efficient implementation.
Real applications should make use of the USART's peripheral DMA channel (PDC).
mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is defined in main.c. The behaviour of the
demo depends on its setting.
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1 then main() will
call main_blinky(). main_blinky() creates a very simple demo as follows:
The main_blinky() Function:
main_blinky() creates one queue, and two tasks. It then starts the
RTOS scheduler.
The Queue Send Task:
It sends the value 100 to the queue every 200 milliseconds.
The Queue Receive Task:
in main_blinky.c. It repeatedly reads from the queue with a block time
specified, causing it to enter the Blocked state
if the queue is empty. The task toggles the red/orange LED each time the value 100 is
received from the queue, therefore, because the queue send task sends to
the queue every 200 milliseconds, the queue receive task should exit
the Blocked state and toggle the red/orange LED every 200 milliseconds.
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0 then main() will
call main_full(). main_full() creates a comprehensive test and demo application
that demonstrates:
The created tasks are from the set of standard demo
tasks. Standard demo tasks are used by all FreeRTOS port demo applications.
They have no specific functionality, and are created just to demonstrate how to use the FreeRTOS API,
and test the RTOS port.
main() creates 34 tasks and three software timers before
starting the RTOS scheduler. The demo then dynamically and continuously creates and
deletes a further two tasks while it is running.
A 'check' software timer is created that periodically inspects the standard
demo tasks to ensure all the tasks are functioning
as expected. The check software timer's
callback function toggles the green LED on the SAM3 development hardware.
This gives visual feedback of the
system health. If the green LED is toggling every 3 seconds, then the
check software timer has not discovered any problems. If the LED is
toggling every 200 milliseconds, then the check software timer has
discovered a problem in one or more tasks. This mechanism can be tested by
removing the loopback connector, and in so doing, deliberately causing the
com test tasks to fail.
Atmel Studio requires all the source files built by a project to be located in, or
in subdirectories of, the directory that contains the Atmel Studio project itself.
It is therefore necessary to copy the FreeRTOS
and standard demo source files used by the demo applications from
their locations in the standard FreeRTOS directory structure into the demo
directory. A batch file called CreateProjectDirectoryStructure.bat is provided
for this purpose.
CreateProjectDirectoryStructure.bat is located in the same directory that
contains the Atmel Studio 6 solution,
and must be executed before the demo application can be
built successfully.
Ensure the CreateProjectDirectoryStructure.bat batch file has been executed.
Open either the FreeRTOS/Demo/CORTEX_ATSAM3S-EK2_Atmel_Studio/RTOSDemo.atsln
or FreeRTOS/Demo/CORTEX_ATSAM3X_Atmel_Studio/RTOSDemo.atsln (as
appropriate) from within the Atmel Studio IDE.
Open main.c, and set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to generate either
the simply blinky demo, or the full test and demo application, as
required.
Ensure the target hardware is connected to the host computer using a
suitable J-Link or SAM-ICE interface. The project was created using a
J-Link.
Select 'Build Solution' from the IDE's 'Build' menu, the
RTOSDemo project should build without any errors or warnings.
After the build completes, select "Start Debug and Break" from the IDE's Debug
menu to program the SAM3 microcontroller flash memory, start a debug
session, and have the debugger break on entry into the main() function.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_ATSAM3S-EK2_Atmel_Studio/src/FreeRTOSConfig.h
or FreeRTOS/Demo/CORTEX_ATSAM3X_Atmel_Studio/src/FreeRTOSConfig.h, depending on the project in use.
configTICK_RATE_HZ
testing the RTOS kernel functionality but is faster than most applications need.
Lowering the frequency will improve efficiency.
configLIBRARY_LOWEST_INTERRUPT_PRIORITY and configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY
Whereas configKERNEL_INTERRUPT_PRIORITY and configMAX_SYSCALL_INTERRUPT_PRIORITY
are full eight bit shifted values, defined to be used as raw numbers directly
in the ARM Cortex-M3 NVIC registers, configLIBRARY_LOWEST_INTERRUPT_PRIORITY
are equivalents that are defined using just the 4 priority bits implemented in the SAM3
NVIC.
These values are provided because the CMSIS library function NVIC_SetPriority()
requires the un-shifted 4 bit format.
ARM Cortex-M microcontroller manufacturers implement a different number of priority bits and supply library
on Atmel SAM3 ARM Cortex-M3 microcontrollers, the lowest priority you can specify is in fact 15 - this is defined by the constant
being preemption priority bits, and none as sub priority bits, as they are in the provided
demo.
uses a semaphore to synchronise with a task (not shown), and calls portEND_SWITCHING_ISR
to ensure the interrupt returns directly to the task. See the function
USART1_Handler() in the file serial.c included in this demo project for another
example.
internally within xSemaphoreGiveFromISR(). Passing pdTRUE into the
configuration constant (or configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY).
Set the definition configUSE_PREEMPTION within FreeRTOSConfig.h to 1 to use pre-emption or 0
selected.
Source/Portable/MemMang/heap_4.c is included in the ARM Cortex-M3 demo application project to provide the memory
full information.
