Using IAR and Keil - Including an embedded web server with CGI scripting
[Embedded Ethernet Examples]
This page documents a FreeRTOS ARM Cortex-M3 demo application that targets the Microsemi (formally Actel)
SmartFusion mixed signal FPGA with integrated ARM Cortex-M3 microcontroller subsystem.
FreeRTOS includes ARM Cortex-M3 ports for the IAR, Keil and GCC compilers. Demo application
projects targeting the SmartFusion are provided for the IAR Embedded Workbench, Keil MDK
and SoftConsole (Eclipse) IDEs. This page provides instruction on using the IAR and Keil IDEs only.
A separate page provides instructions on using the SoftConsole Eclipse IDE.
The IAR and Keil projects are pre-configured to run on the
A2F-EVAL-KIT
SmartFusion evaluation board.
Note: If this project fails to build using the IAR tools then it is likely the version of IAR
Embedded Workbench being used is too old. If this is the case, then it is also
likely that the project file has been (silently) corrupted and will need to be
restored to its original state before it can be built even with an updated IAR version.
An example embedded web server implementation is included. This makes use of a modified version of the
tiny uIP TCP/IP stack.
Code-named FreeTCPIP, the modifications to the TCP/IP stack allow a higher
throughput than can be achieved with the original code. Dynamic web pages showing
RTOS, TCP/IP and task run time statistics are
created and served using the standard uIP CGI scripting facility.
uIP was originally written by Adam Dunkels. It is open source, but licensed
separately from FreeRTOS. Users must familiarise themselves with the
uIP licence, which is detailed at the top of each uIP source file.
IMPORTANT! Notes on using the FreeRTOS IAR and Keil SmartFusion example projects
- Source Code Organisation
- The Demo Application
The IAR Embedded Workbench workspace for the SmartFusion A2F demo is called RTOSDemo_IAR.eww, and is located in the
FreeRTOS/Demo/CORTEX_A2F200_IAR_and_Keil directory.
The Keil MDK project for the SmartFusion A2F demo is called RTOSDemo_Keil.uvproj, and is also located in the
The FreeRTOS zip file download contains source code for all the FreeRTOS ports,
and every demo application project.
It therefore contains many more files than are required to build and run the SmartFusion demo. See the
of the downloaded files, and information on creating a new project.
Build configuration
Description
Blinky
This is a very simple example. It creates two tasks,
one software timer, and also uses a button interrupt.
The two tasks communicate via a queue, with the receiving task
toggling an LED each time a value is received.
Pressing user button SW1 generates an interrupt, the service routine
for which resets a software timer before turning an LED on.
The software timer has a five second period, and when the five
seconds expire, the timer callback function turns the LED off again.
Therefore, pressing SW1 will turn the LED on, and the LED will
remain on until a full five seconds pass without the button being
pressed again.
The Blinky build configuration uses the
main-blinky.c source file. The other two build configurations use
the main-full.c source file.
Full
This is a comprehensive demo that creates lots of tasks,
queues, semaphores (of various types) and software timers.
The Full build configuration creates the same tasks and timers that are
created by the Blinky build configuration. In addition to these,
the Full build configuration also creates a lot of tasks from the set of
standard demo
tasks. The standard demo tasks don't perform any particular function.
Their purpose is firstly to test the FreeRTOS port, and secondly to
provide examples of how to use the FreeRTOS API functions.
The Full build configuration creates yet more tasks that are neither
part of the Blinky configuration or the set of standard demo tasks.
These additional tasks are described briefly below this table.
Full_with_optimisation
The functionality of the Full_with_optimisation build configuration
is identical to that of the Full build configuration. The compiler
optimisation setting is the only difference between the two.
Tasks and timers that are created by both Full build configurations, that are
not part of either the Blinky demo, or the standard demo tasks, include:
- A "Check" software timer and callback
Each time the check timer expires, its associated callback function
queries the status of all the running standard demo tasks. If any queried
status is returned as 'failed', then the period of the Check timer is shortened
to 500ms from its original setting of 3 seconds.
The check timer callback toggles LED D8 each time it executes. Therefore,
if LED D8 toggles every three seconds, then no errors have been discovered.
If LED D8 toggles every 500ms, then at least one standard demo task has
reported an error. The name of the standard demo task that reported the
error can be viewed using the embedded web server - it is displayed at the
bottom of the "task stats" web page, under the task stats table.
- uIP task
All TCP/IP related processing is contained in the uIP task. The Flash and RAM
footprint of the TCP/IP stack is extremely small compared to other embedded
TCP/IP implementations.
- OLED task
The OLED task scrolls a message across both rows of the OLED.
Web server configuration
The demo application includes an embedded web server. The IP address used by the
web server is fixed, and set set by the constants configIP_ADDR0 to
configIP_ADDR3. The definition of these constants can be found near the bottom
of the FreeRTOSConfig.h header file, which is itself located in the same
directory as the IAR and Keil demo project files.
Constants that define the MAC address, and the NET mask, are located in the same
header file.
The IP addresses used by the web server running on the SmartFusion device, and
the web browser used to connect to the web server, must be
compatible with each other. To ensure this is the case, make the first three
octets of both IP addresses the same. For example, if the web browser computer
uses IP address 10.10.10.1, then the SmartFusion device can be given any IP
address in the range 10.10.10.2 to 10.10.10.254 - other than any IP addresses
that are already present on the same network.
The MAC address assigned to the SmartFusion device must be unique on the network
to which the device is being connected.
This section provides instructions on the hardware set up required to
program an application into the ARM Cortex-M3 flash memory. It is assumed that the
FPGA fabric and ACE are already configured correctly, which will be the case if
the configuration has not been changed from that shipped. However, if the FPGA fabric
or ACE configuration has been altered from that shipped, and you find the demo
application does not execute correctly, then it is recommended to restore the FPGA
fabric and ACE configuration using the .pdb file supplied
with the A2F-EVAL-KIT.
Ensure jumpers JP7 and JP10 are set to the RVI and M3 positions respectively.
If you are using the IAR Embedded Workbench, then connect a J-Link
debugger interface to the connector labelled "RVI-HEADER".
If you are using the Keil MDK, then connect a U-Link debugger
Use an Ethernet cable to connect the A2F-EVAL-KIT hardware to a computer
running a standard web browser. This needs to be done either directly,
by using a crossover (point to point) Ethernet cable, or through a
hub/switch, using a standard Ethernet cable. Only the direct connection
option was tested during development of the demo, but both methods
should work.
Power the A2F-EVAL-KIT using the USB connector J14.
Open the RTOSDemo_IAR.eww Embedded Workbench workspace
from within the Embedded Workbench IDE.
If you wish to use the embedded
web server, then select either the Full or the Full_with_optimisation
build configuration. If you want to start with a very simple example,
then select the Blinky build configuration.
Select "Build All" from the Embedded Workbench "Project" menu - the demo
application should build without errors.
When the build completes, select "Download and Debug" from the Embedded Workbench
"Project" menu (or just press CTRL+D) to program the microcontroller flash memory,
and start a debug session. The application will start to run, and then
break on entry to the main() function.
Open the RTOSDemo_Keil.uvproj project from within
the Keil IDE.
then select the Blinky build configuration. (Build configurations are
called 'targets' in the MDK environment).
Select "Build Target" from the IDE's "Project" menu - the demo application should
When the build complete, select "Start/Stop Debug Session" from the IDE's
"Debug" menu (or just press CTRL+F5) to program the microcontroller flash memory,
Demo functionality
Served web Pages
The served IO page
The IO page provides a simple interface to permit two LEDs to be turned on and off from a web browser.
It also displays the current raw analogue input reading from the 50K potentiometer that is located
next to the OLED on the evaluation board. Changes are sent to the target board whenever the "Update IO" button is clicked.
Values displayed on the IO page are updated each time the "Update IO" button is clicked, or the served
web page is refreshed.
Other served pages include TCP/IP statistics, and a large JPG image. All the web pages are included in the downloaded
binary image - which can make the binary image appear to be quite large (the jpg file by itself is in excess of 36K).
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_A2F200_IAR_and_Keil/FreeRTOSConfig.h.
- configTICK_RATE_HZ
Attention please!: Remember that ARM Cortex-M3 cores use
The lowest priority on a ARM Cortex-M3 core is in fact 255 - however different
Cortex-M3 vendors implement a different number of priority bits and supply library
on the A2F the lowest priority you can specify is in fact 15 - this is defined by the constant
It is also recommended to ensure that all four priority bits are assigned as
being premption priority bits, and none as sub priority bits.
Unlike most ports, interrupt service routines that cause a context switch have
This demo project provides examples of FreeRTOS interrupt service routines -
namely GPIO8_IRQHandler() defined in main-full.c and main-blinky.c, and the
Ethernet MAC interrupt handler.
configuration constant.
selected.
Source/Portable/MemMang/heap_2.c is included in the SmartFusion A2F demo application project to provide the memory
full information.
