FreeRTOS SMP:
Embedded World track keynote:
xTimerChangePeriodFromISR
 BaseType_t xTimerChangePeriodFromISR
              TimerHandle_t xTimer,
              TickType_t xNewPeriod,
A version of xTimerChangePeriod() that can be called from an interrupt service routine.
xTimer   The handle of the software timer that is having its period changed.
xNewPeriod   The new period for xTimer. Timer periods are specified in tick periods, so the constant portTICK_PERIOD_MS can be used to convert a time that has been specified in milliseconds. For example, if the timer must expire after 100 ticks, then xNewPeriod should be set to 100. Alternatively, if the timer must expire after 500ms, then xNewPeriod can be set to ( 500 / portTICK_PERIOD_MS ) provided configTICK_RATE_HZ is less than or equal to 1000.
pxHigherPriorityTaskWoken   The timer service/daemon task spends most of its time in the Blocked state, waiting for messages to arrive on the timer command queue. Calling xTimerChangePeriodFromISR() writes a message to the timer command queue, so has the potential to transition the timer service/ daemon task out of the Blocked state. If calling xTimerChangePeriodFromISR() causes the timer service/daemon task to leave the Blocked state, and the timer service/daemon task has a priority equal to or greater than the currently executing task (the task that was interrupted), then *pxHigherPriorityTaskWoken will get set to pdTRUE internally within the xTimerChangePeriodFromISR() function. If xTimerChangePeriodFromISR() sets this value to pdTRUE, then a context switch should be performed before the interrupt exits.
pdFAIL will be returned if the command to change the timers period could not be sent to the timer command queue. pdPASS will be returned if the command was successfully sent to the timer command queue. When the command is actually processed will depend on the priority of the timer service/daemon task relative to other tasks in the system. The timer service/daemon task priority is set by the configTIMER_TASK_PRIORITY configuration constant.
/* This scenario assumes xTimer has already been created and started.  When
an interrupt occurs, the period of xTimer should be changed to 500ms. */
/* The interrupt service routine that changes the period of xTimer. */
    /* The interrupt has occurred - change the period of xTimer to 500ms.
    (within this function).  As this is an interrupt service routine, only
    if( xTimerChangePeriodFromISR( xTimer,
                                   pdMS_TO_TICKS( 500 ),
        /* The command to change the timers period was not executed
        successfully.  Take appropriate action here. */
    actual syntax required. */
