FreeRTOS SMP:
Embedded World track keynote:
xTimerResetFromISR
 BaseType_t xTimerResetFromISR
                   TimerHandle_t xTimer,
A version of xTimerReset() that can be called from an interrupt service routine.
xTimer   The handle of the timer that is to be started, reset, or restarted.
pxHigherPriorityTaskWoken   The timer service/daemon task spends most of its time in the Blocked state, waiting for messages to arrive on the timer command queue. Calling xTimerResetFromISR() writes a message to the timer command queue, so has the potential to transition the timer service/daemon task out of the Blocked state. If calling xTimerResetFromISR() causes the timer service/daemon task to leave the Blocked state, and the timer service/ daemon task has a priority equal to or greater than the currently executing task (the task that was interrupted), then *pxHigherPriorityTaskWoken will get set to pdTRUE internally within the xTimerResetFromISR() function. If xTimerResetFromISR() sets this value to pdTRUE then a context switch should be performed before the interrupt exits.
pdFAIL will be returned if the reset command could not be sent to the timer command queue. pdPASS will be returned if the command was successfully sent to the timer command queue. When the command is actually processed will depend on the priority of the timer service/daemon task relative to other tasks in the system, although the timers expiry time is relative to when xTimerResetFromISR() is actually called. The timer service/daemon task priority is set by the configTIMER_TASK_PRIORITY configuration constant.
service routine. */
parameter is not used. */
    if( xTimerResetFromISR( xBacklightTimer,
        action here. */
    actual syntax required. */
