Cortex-A53 Xilinx UltraScale MPSoC
64-bit (AArch64) RTOS Demo
The Xilinx SDK (Software Development Kit) includes wizards that create FreeRTOS projects for all the cores found on the Zynq UltraScale MPSoC, which includes ARM Cortex-A53 (AArch64, 64-bit), ARM Cortex-R5, and Microblaze processors.
This page documents a FreeRTOS demo application that targets a 64-bit ARM Cortex-A53 (AArch64) core on a Xilinx Zynq UltraScale+ MPSoC. A similar project that targets an ARM Cortex-R5 core on the same device is provided separately.
The demo uses a standalone BSP (which is the Board Support Package generated by the SDK), and builds FreeRTOS as part of the application. The hardware design project targets the ZCU102 Evaluation Kit.
FreeRTOS is also distributed as part of the Xilinx SDK package, and the SDK includes wizards to generate FreeRTOS for the UltraScale+ MPSoC's 64-bit ARM Cortex-A53, ARM Cortex-R5 and Microblaze cores. When the SDK generates a project FreeRTOS is built as part of the BSP, rather than part of the application. Instructions for this are also provided.
The 64-bit ARM Cortex-A53 FreeRTOS port implements a full interrupt nesting model, and supports the floating point unit (FPU).
IMPORTANT! Notes on using the FreeRTOS 64-bit ARM Cortex-A53 port
  3. Build Instructions
The FreeRTOS download contains the source code for all the FreeRTOS ports, and every demo application. That means it contains many more files than are required to use the Zynq UltraScale+ Cortex-A53 MPSoC port and demo application. See the Source Code Organization section of this web site for a description of the downloaded files, and information on creating a new project.
The directory structure used by the demo application is shown and described below. The root CORTEX_A53_64-bit_UltraScale_MPSoC directory is itself located in FreeRTOS/Demo.
  +-RTOSDemo_A53              Contains the SDK project and C files specific to the demo.
  +-RTOSDemo_A53_bsp          Contains the hardware board support package.
  • The projects contained in the ZynqMP_ZCU102_hw_platform and RTOSDemo_A53_bsp directories were created by the Xilinx SDK.
  • The RTOSDemo_A53 directory only contains the source files that are specific to the Zynq UltraScale+ MPSoC demo. The FreeRTOS source files, and the source files that implement tasks that are common to all demo applications, are located elsewhere in the directory tree. Therefore the project will only build when the default directory structure is unchanged. Also see the page that describes how to use virtual and linked paths in the Eclipse project explorer.
The Zynq UltraScale+ MPSoC ARM Cortex-A53 Demo Application
The constant mainSELECTED_APPLICATION, which is #defined at the top of main.c, is used to switch between a simply Blinky style demo and a more comprehensive test and demo application.
main_blinky() creates a very simple demo that includes two tasks and one queue. One task uses the queue to repeatedly send the value 100 to the other task. The receiving task prints a message to the USB UART port (J83) each time the message is received. 115200 baud is used.
The message is sent to the queue every 200 milliseconds, so the message is printed to the UART every 200 milliseconds.
Most of the tasks created by the demo are from the set of standard demo tasks. These are used by all FreeRTOS demo applications, and have no specific functionality or purpose other than to demonstrate the FreeRTOS API being used, and test the RTOS port.
    Two timers are used to test interrupt nesting, and test RTOS queues being used from nested interrupts.
  • Register test tasks
    The register test tasks test the RTOS context switch mechanism by first filling each ARM Cortex-A53 register (including the floating point registers) with a known and unique value, then repeatedly checking that the value originally written to the register remains in the register for the lifetime of the task. The nature of these tasks necessitates that they are written in assembly.
  • A 'check' task
    The check task periodically queries the standard demo tasks, and the register test tasks, to ensure they are functioning as intended - then prints a status message to the USB UART (J83). 115200 baud is used.
    The output generated when the RTOS demo is executed on a 64-bit ARM Cortex-A53 core on the Zynq UltraScale+ MPSoC
Hardware setup
All four switches on bank SW6 need to be set toward the centre of the board in order to enable downloading and executing over the JTAG interface.
Build Instructions - Using the Official FreeRTOS Demo
This section describes how to build the demo described immediately above. The section that follows after describes how to use the Xilinx SDK to create and build a FreeRTOS project.
  2. In the next dialogue box, select FreeRTOS/Demo/CORTEX_A53_64-bit_UltraScale_MPSoC as the root directory. Then, make sure the RTOSDemo_A53, RTOSDemo_A53_bsp and ZynqMP_ZCU102_hw_platform projects are checked in the "Projects" area, and that the Copy Projects Into Workspace box is not checked, before clicking the Finish button (see the image below for the correct check box states).
    Importing the free ARM Cortex-A53 64-bit RTOS Demo Source project into the Xilinx SDK
    The ZynqMP_ZCU102_hw_platform and RTOSDemo_A53_bsp projects are dependencies of the RTOSDemo_A53 project, so only the RTOSDemo_A53 project needs to be built explicitly.
    The ARM Cortex-A53 RTOS projects viewed in the Eclipse project explorer.
Building the demo application
Starting a debug session
  1. Ensure the ZCU102 evaluation board is powered up and connected to the host computer using an appropriate debug interface.
    64-bit ARM Cortex-A53 target setup tab
    64-bit ARM Cortex-A53 RTOS application tab
  6. Click the "Debug" button to commence debugging. The application will be downloaded to RAM and the debugger will break on entry to main(). It may be necessary to select the correct ARM Cortex-A53 core in the Debug window in order to see the correct source code, and use the debugging controls.
    Selecting the ARM Cortex-A53 core in order to debug the RTOS project
    Selecting the ARM Cortex-A53 #0 core in the debug window
Build Instructions - Creating a Basic Project Using the SDK
The previous section described how to build the official FreeRTOS project that comes in the main FreeRTOS zip file download. FreeRTOS also ships with the Xilinx SDK. This section describes how to create a FreeRTOS project using the SDK.
    Creating a new RTOS project
  2. In the New Project dialogue box, first select "psu_cortexa53_0" as the processor, then select the hardware platform as appropriate, and finally select freertos as the OS platform before clicking "Next". The New Project Templates dialogue will appear.
    The required New Project settings to create a Cortex-A53 RTOS project
    RTOS template for 64-bit port
Configuring a FreeRTOS BSP
Configuration items specific to this demo are contained in /FreeRTOS/Demo/CORTEX_A53_64-bit_UltraScale_MPSoC/RTOSDemo_A53/src/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application.
Interrupt vector table
By default, SDK projects define the interrupt vector table as part of the BSP. This makes it difficult to install the FreeRTOS handlers using the methods described on the page about running FreeRTOS on ARM Cortex-A embedded processors. Therefore, this demo defines its own interrupt vector table in FreeRTOS_asm_vectors.S. The vector table defined by the BSP is automatically replaced by the vector table defined in FreeRTOS_asm_vectors.S when the scheduler is started.
Unlike when running the RTOS on the Zynq 7000, you cannot re-enable interrupts in the ARM Cortex-A53 port until after the source of the interrupt has been cleared.
This demo uses drivers provided by Xilinx to configure the interrupt controller, and install application defined interrupts. Examples can be found in FreeRTOS/Demo/CORTEX_A53_64-bit_UltraScale_MPSoC/RTOSDemo_A53/src/Full_Demo/IntQueueTimer.c, which implements and installs the interrupt service routines used by the interrupt nesting test.
Information is provided on the Using FreeRTOS on ARM Cortex-A Embedded Processors page. This demo is configured to generate the tick interrupt from a TTT channel.
The FreeRTOSConfig.h header file used by the demo has both configSUPPORT_STATIC_ALLOCATION and configSUPPORT_DYNAMIC_ALLOCATION defined, and the demo shows both methods being used. Source/Portable/MemMang/heap_4.c is included in the 64-bit ARM Cortex-A53 demo application project to provide the memory allocation required when objects are created using dynamic memory allocation. Please refer to the Memory Management section of the API documentation for full information.
