On this page:
Getting started
Blocking reads and Trigger Levels
Blocking Writes
Send and Receive Complete Macros (for multicore use)
Stream buffers allow a stream of bytes to be passed from an interrupt service
routine to a task, or from one task to another task. A byte
stream can be of arbitrary length and does not necessarily have a beginning or end.
Any number of bytes can be written in one go, and any number of bytes can be
read in one go. Data is passed by copy - the data is copied into the
buffer by the sender and out of the buffer by the read.
Unlike most other FreeRTOS
communications primitives, stream buffers are optimised for single reader single writer
scenarios, such as passing data from an interrupt service routine to a task, or
from one microcontroller core to another on a dual core CPU.
source file in the build.
The stream buffer implementation uses
direct to task notifications. Therefore, calling a stream buffer API function that places
the calling task into the Blocked state can change the calling task's notification
state and value.
IMPORTANT NOTE: Uniquely among FreeRTOS objects, the
stream buffer implementation (so also the message buffer
implementation, as message buffers are built on top of stream buffers) assumes there is only one task or
interrupt that will write to the buffer (the writer), and only one task or
interrupt that will read from the buffer (the reader). It is safe for the
writer and reader to be different tasks or interrupts, but, unlike other
FreeRTOS objects, it is not safe to have multiple different writers or
multiple different readers. If there are to be multiple different writers
then the application writer must place each call to a writing API function
(such as xStreamBufferSend()) inside a
critical section and use a send block time of 0. Likewise, if there
are to be multiple different readers then the application writer must place
each call to a reading API function (such as xStreamBufferReceive()) inside a
critical section and use a receive block time of 0.
The FreeRTOS/Demo/Common/Minimal/StreamBufferInterrupt.c source file
provides a heavily commented example of how to use a stream buffer to pass data
from an interrupt service routine to a task.
See the stream buffer section of the
user documentation for a list of stream buffer
related API functions, in many cases including code snippets that demonstrate
the functions being used.
xStreamBufferReceive() is used to read
data out of a stream buffer from an RTOS task.
xStreamBufferReceiveFromISR()) is
used to read data out of a stream buffer from an interrupt service routine (ISR).
xStreamBufferReceive() allows a block time to be specified. If a non zero
block time is specified when a task
uses xStreamBufferReceive() to read from a stream buffer that happens to be empty
the task will be placed
into the Blocked state (so it is not consuming any CPU time and other tasks can
run) until either a specified amount of data becomes available in the stream
buffer, or the block time expires. The amount of data that must be in the stream buffer before a task that is
waiting for data is removed from the blocked state is called the stream buffer's
Trigger Level. For example:
If a task is blocked on a read of an empty stream buffer that has a
trigger level of 1 then the task will be unblocked when a single byte is
written to the buffer or the task's block time expires.
trigger level of 10 then the task will not be unblocked until the stream
buffer contains at least 10 bytes or the task's block time expires.
If a reading task's
block time expires before the trigger level is reached then the task will still
receive however many bytes are actually available.
Notes:
It is not valid to set the trigger level to 0. Attempting to set the
trigger level to 0 will result result in a trigger level of 1 being used.
It is also not valid to specify a trigger level that is greater than the
stream buffer's size.
The stream buffer's trigger level is initially set when the stream buffer is
created, and can then be changed using
the xStreamBufferSetTriggerLevel()
API function.
xStreamBufferSend()) is used to send
data to a stream buffer from an RTOS task.
xStreamBufferSendFromISR()) is
used to send data to a stream buffer from an interrupt service routine (ISR).
If a non zero block time is specified when a task uses xStreamBufferSend() to
write to a stream buffer that happens to be full the task will be placed into
the Blocked state (so it is not consuming any CPU time and other tasks can run)
until either space becomes available in the stream buffer, or the block time
expires.
[Also see the blog on using message buffers for dual core - core to core communication.]
sbSEND_COMPLETED() (and sbSEND_COMPLETED_FROM_ISR())
sbSEND_COMPLETED() is a macro that is called (internally within the FreeRTOS
API functions) when data is written to a stream buffer. It takes a single
parameter, which is the handle of the stream buffer that was updated.
sbSEND_COMPLETED()
checks to see if there is a task blocked on the stream buffer to wait for data,
and if so, removes the task from the Blocked state.
It is possible for the application writer to change this default behaviour by
providing their own implementation of sbSEND_COMPLETED() in FreeRTOSConfig.h.
That is useful when a stream buffer is used to pass data between cores on a
multicore processor. In that scenario, sbSEND_COMPLETED() can be implemented
to generate an interrupt in the other CPU core, and the interrupt's service
routine can then use the xStreamBufferSendCompletedFromISR() API function to
check, and if necessary unblock, a task that was waiting for the data.
The FreeRTOS/Demo/Common/Minimal/MessageBufferAMP.c source file
provides a heavily commented example of exactly that scenario.
sbRECEIVE_COMPLETED() (and sbRECEIVE_COMPLETED_FROM_ISR())
sbRECEIVE_COMPLETED() is the receive equivalent of sbSEND_COMPLETED(). It is
called (internally within the FreeRTOS API functions) when data is read from a
stream buffer. The macro checks to see if there is a task blocked on the stream
buffer to wait for space to become available within the buffer, and if so,
removes the task from the Blocked state. Just as with sbSEND_COMPLETED(), the
default behaviour of sbRECEIVE_COMPLETED() by providing an alternative implementation
in FreeRTOSConfig.h
