Using FreeRTOS on RISC-V Microcontrollers
Preamble
As noted on the
Upgrading to FreeRTOS V10.3.0
page, the
configCLINT_BASE_ADDRESS configuration setting has been deprecated and
replaced by the
configMTIME_BASE_ADDRESS and
configMTIMECMP_BASE_ADDRESS
settings described on this page. Legacy applications that still use configCLINT_BASE_ADDRESS
will generate a compiler warning, but otherwise continue to build and function as
before.
The RISC-V instruction set architecture (ISA) is easily extensible and does not
specify everything about physical RISC-V microcontroller or system on chip (SoC)
implementations. Accordingly, the FreeRTOS RISC-V port is also extensible - it
provides a base port that handles the registers common to all RISC-V
implementations, and
a set of macros
that must be implemented to handle hardware implementation specific features and
extensions, such as additional registers.
The main body of this page provide detailed information on building
FreeRTOS for RISC-V cores, but the simplest way to get started is to use one
of the following pre-configured example projects (list correct at the time of
writing):
The example RISC-V projects are
located in the sub-directories of FreeRTOS/Demo that start "RISC-V"
in the main FreeRTOS zip file download. These projects can be used directly,
or simply as a worked example and reference for the source files,
configuration options, and compiler settings detailed below.
In summary, to build FreeRTOS for a RISC-V core you need to:
Include the core FreeRTOS source
files and the FreeRTOS RISC-V port layer source files in your
project.
Ensure the assembler's include path
includes the path to the header file that describes any chip specific
implementation details.
Define either a constant in FreeRTOSConfig.h or a linker variable
to specify the memory to use as the
interrupt stack.
Define configMTIME_BASE_ADDRESS and configMTIMECMP_BASE_ADDRESS
in FreeRTOSConfig.h.
For the assembler, #define
portasmHANDLE_INTERRUPT to the name of the function provided by your
chip or tools vendor for handling external interrupts.
Install the
FreeRTOS trap handler.
Other links that may be helpful include:
Detailed information
On this page:
The FreeRTOS RISC-V port:
Is provided for both the GCC and IAR compilers.
Supports machine mode integer execution on 32-bit and 64-bit RISC-V cores only, but
is under active development, and future FreeRTOS releases will add features
and functionality as required by our users.
Implements a separate interrupt stack, and in so doing, greatly reduces
RAM usage on small microcontrollers by removing the need for every task
to have a stack large enough for both interrupt and non-interrupt stack
frames.
Provides a base port that can be easily extended to accommodate RISC-V
implementation specific architecture extensions.
The
FreeRTOS kernel source code organization page
contains information on adding the FreeRTOS kernel to your project. In addition
to the information on that page, the FreeRTOS RISC-V port requires one additional
header file. The additional header file describes chip specific details, and is
required because RISC-V chips often include chip specific architecture extensions.
The additional header file is called freertos_risc_v_chip_specific_extensions.h. There
is one implementation of this header file for each supported architecture extension, with
all implementations located in subdirectories of the
/FreeRTOS/Source/Portable/[compiler]/RISC-V/chip_specific_extensions
directory.
To include the correct freertos_risc_v_chip_specific_extensions.h
header file for your chip simply add the path
to that header file to the assembler's include path (note this is the
assembler's include path, not the compiler's include path). For example:
If your chip implements the base RV32I or RV64I architecture, includes a
Core Local Interrupter (CLINT), but has no other register extensions,
then add
/FreeRTOS/Source/Portable/[compiler]/RISC-V/chip_specific_extensions/RV32I_CLINT_no_extensions
to the assembler's include path.
If your chip uses a PULP RI5KY core as implemented on the RV32M1RM Vega
board, which includes six additional registers and does not include a
a Core Local Interrupter (CLINT), then add
/FreeRTOS/Source/Portable/[compiler]/RISC-V/chip_specific_extensions/Pulpino_Vega_RV32M1RM
Also see
the
compiler and assembler command line
options section below for information on setting assembler command line options, and the
porting FreeRTOS to new RISC-V implementations
section for information on creating your own
header files.
configMTIMECMP_BASE_ADDRESS must be defined in
FreeRTOSConfig.h.
If the target RISC-V chip includes a machine timer (MTIME) then set
configMTIME_BASE_ADDRESS to the MTIME base address and configMTIMECMP_BASE_ADDRESS
to the address of the MTIME's compare register (MTIMECMP). Otherwise set both
definitions to 0.
For example, if the MTIME base address is 0x2000BFF8 and the MTIMECMP address is 0x20004000, then add the following
lines to FreeRTOSConfig.h:
#define configMTIME_BASE_ADDRESS ( 0x2000BFF8UL )
#define configMTIMECMP_BASE_ADDRESS ( 0x20004000UL )
If there is no MTIME clock, then add the following lines to
FreeRTOSConfig.h:
#define configMTIME_BASE_ADDRESS ( 0 )
#define configMTIMECMP_BASE_ADDRESS ( 0 )
The FreeRTOS RISC-V port switches to a dedicated interrupt (or system) stack before
any C functions are called from an interrupt service routine (ISR).
The memory to use as the interrupt stack can either be defined in the linker
script or declared within the FreeRTOS port layer as a statically allocated array. The
linker script method is preferred on memory constrained MCUs as it allows the stack that was
used by main() prior to the scheduler being started (which is no longer used for
that purpose after the scheduler has been started) to be re-purposed as the
interrupt stack.
To use a statically allocated array as the interrupt stack:
Define configISR_STACK_SIZE_WORDS in FreeRTOSConfig.h to the
size of the interrupt stack to be allocated. Note the size is defined
in words, not bytes.
For example, to use a 500 word (2000 bytes on an RV32, where each word
is 4 bytes) statically allocated interrupt stack add the following to
FreeRTOSConfig.h:
#define configISR_STACK_SIZE_WORDS ( 500 )
To defined the interrupt stack in the linker script - note at the time
of writing this method is only supported in the GCC port:
Declare a linker variable called __freertos_irq_stack_top that holds
the highest address of the interrupt stack, and
Ensure configISR_STACK_SIZE_WORDS is not defined.
Using this method requires editing the linker script. If you are not
familiar with linker scripts then it is important to know, when using
GCC at least, that '.' is what is known as the
location counter, and holds the value of the memory address at that
point in the linker script.
There is no need to understand the fine details of linker scripts though,
just copy the example below.
The stack that was used by main() before the scheduler is started is no
longer required after the scheduler is started, so ideally reuse that
stack by setting __freertos_irq_stack_top to equal the value of the
highest address of the stack allocated for use by main(). For example,
if your linker script contains something like the below (the actual
linker scripts in use will vary):
.stack : ALIGN(0x10)
__stack_bottom = .;
. += STACK_SIZE;
__stack_top = .;
} > ram
Then __stack_top (example name only) is a linker variable, the
value of which equals the highest address
of the stack used by main() (recall '.' holds the value of the memory address
at any given place in the linker script). In this case, to give
__freertos_irq_stack_top the same value as __stack_top,
just define __freertos_irq_stack_top immediately after __stack_top.
See the example below:
__stack_bottom = .;
. += STACK_SIZE;
__stack_top = .;
__freertos_irq_stack_top= .; /* ADDED THIS LINE. */
} > ram
Note:
at the time of writing, unlike with task stacks, the kernel does not check for
overflows in the interrupt stack.
Different RISC-V implementations provide different handlers for external interrupts,
so it is necessary to tell the FreeRTOS kernel which external interrupt handler
to call. To set the name of the external interrupt handler:
Locate the name of the external interrupt handler provided by your RISC-V
run-time software distribution - this is normally the software provided
by the chip vendor. The interrupt handler must have one parameter,
which is the value of the RISC-V cause register at the time the
interrupt was entered. For example, the prototype of the interrupt
handler is expected to be (sample name only, use the correct name for
your software):
void external_interrupt_handler( uint32_t cause );
Define an assembler macro (note this is an assembler macro, not
a compiler macro) called portasmHANDLE_INTERRUPT to equal the
name of the interrupt handler.
If using GCC this can be achieved by adding the following to the
assembler's command line, assuming the interrupt handler is called
external_interrupt_handler:
-DportasmHANDLE_INTERRUPT=external_interrupt_handler
If using IAR this can be achieved by opening the project options dialog
box and adding the following line as a defined symbol within the Assembler
category, assuming the interrupt handler is called vApplicationHandleTrap.
portasmHANDLE_INTERRUPT=vApplicationHandleTrap
Setting the IAR assembler options
It is also necessary to add the path to the correct
header file for the RISC-V chip in use to the assembler's include path (note this is the
assembler's include path, not the compiler's include path). See
the
source files section above.
The FreeRTOS trap handler is called
freertos_risc_v_trap_handler() and
is the central entry point for all interrupts and exceptions. The FreeRTOS
trap handler calls the
when the source of a trap is an external interrupt.
To install the trap handler:
If the RISC-V core in use includes a Core Local Interrupter (CLINT) then
portasmHAS_SIFIVE_CLINT can be defined to 1 in freertos_risc_v_chip_specific_extensions.h,
which results in the automatic installation of freertos_risc_v_trap_handler(),
so no other specific actions are required.
In all other cases it is necessary to install freertos_risc_v_trap_handler()
manually. That can be done by editing the startup code provided by your
chip provider.
Note: If the RISC-V chip uses a vectored interrupt controller then install
freertos_risc_v_trap_handler() as the handler for each vector.
Read the
FreeRTOS RISC-V source files section above
before reading this section.
The freertos_risc_v_chip_specific_extensions.h file contains the following macros
that must be defined:
- portasmHAS_MTIME
If the chip has a machine timer (MTIME) then set portasmHAS_MTIME to 1,
otherwise set portasmHAS_MTIME to 0.
portasmADDITIONAL_CONTEXT_SIZE
The RISC-V Instruction Set Architecture (ISA) is extensible, so RISC-V chips
may include additional registers over and above those required by the base
architecture specification.
#define portasmADDITIONAL_CONTEXT_SIZE to the number of additional
registers that exist on the target chip - which might be zero. For
example, the RI5CY core on the Vega board includes six additional registers,
so the freertos_risc_v_chip_specific_extensions.h provided for use
with that chip includes the following line:
#define portasmADDITIONAL_CONTEXT_SIZE 6
portasmSAVE_ADDITIONAL_REGISTERS
portasmSAVE_ADDITIONAL_REGISTERS is an assembly macro (not a #define)
that must be implemented to save any chip specific additional registers.
If there are no chip specific extension registers (portasmADDITIONAL_CONTEXT_SIZE
is set to zero) then portasmSAVE_ADDITIONAL_REGISTERS must be an empty
assembly macro as follows:
.macro portasmSAVE_ADDITIONAL_REGISTERS
/* No additional registers to save, so this macro does nothing. */
.endm
If there are chip specific extension registers (portasmADDITIONAL_CONTEXT_SIZE
is greater than zero) then portasmSAVE_ADDITIONAL_REGISTERS must:
Decrement the stack pointer to create enough stack space for the
additional registers, then...
Save the additional registers into the created stack space.
For example, if the chip has three additional registers then
must be implemented as follows (where the names of the registers will be
dependent on the chip, and not as shown here):
/* Use the portasmADDITIONAL_CONTEXT_SIZE and portWORD_SIZE
macros to calculate how much additional stack space is needed,
and subtract that from the stack pointer. This line can just
be copied from here provided portasmADDITIONAL_CONTEXT_SIZE
is set correctly. Note the minus sign ('-'). portWORD_SIZE
is already defined elsewhere. */
addi sp, sp, -(portasmADDITIONAL_CONTEXT_SIZE * portWORD_SIZE)
/* Next save the additional registers, which here are assumed
to be called xx0 to xx2, but will be called something different
on your chip, to the stack. Assumes portasmADDITIONAL_CONTEXT_SIZE
is 3. */
sw xx0, 1 * portWORD_SIZE( sp )
sw xx1, 2 * portWORD_SIZE( sp )
sw xx2, 3 * portWORD_SIZE( sp )
.endm
portasmRESTORE_ADDITIONAL_REGISTERS
portasmRESTORE_ADDITIONAL_REGISTERS is the reverse of
portasmSAVE_ADDITIONAL_REGISTERS.
is set to zero) then portasmRESTORE_ADDITIONAL_REGISTERS must be an empty
.macro portasmRESTORE_ADDITIONAL_REGISTERS
/* No additional registers to restore, so this macro does nothing. */
.endm
is greater than zero) then portasmRESTORE_ADDITIONAL_REGISTERS must:
Read the additional registers from the stack locations used by
portasmSAVE_ADDITIONAL_REGISTERS, then...
Remove the stack space used to hold the additional registers by incrementing
the stack pointer by the correct amount.
For example, if the
chip has three additional registers then portasmRESTORE_ADDITIONAL_REGISTERS
dependent on the chip, not as shown here):
/* Restore the additional registers, which here are assumed
on your chip from the stack. Assumes
portasmADDITIONAL_CONTEXT_SIZE is 3. */
lw xx0, 1 * portWORD_SIZE( sp )
lw xx1, 2 * portWORD_SIZE( sp )
lw xx2, 3 * portWORD_SIZE( sp )
macros to calculate how much space to remove from the stack.
This line can just be copied from here provided
portasmADDITIONAL_CONTEXT_SIZE is set correctly. portWORD_SIZE
addi sp, sp, (portasmADDITIONAL_CONTEXT_SIZE * portWORD_SIZE)
.endm
The freertos_risc_v_chip_specific_extensions.h file can also optinally include:
