stream_buffer.h
size_t xStreamBufferBytesAvailable( StreamBufferHandle_t xStreamBuffer );
Queries a stream buffer to see how much data
it contains, which is equal to the number of bytes that can be read from the
stream buffer before the stream buffer would be empty.
source file in the build.
xStreamBuffer
The handle of the stream buffer being queried.
The number of bytes that can be read from the stream buffer before
