xStreamBufferSendFromISR()
[RTOS Stream Buffer API]
stream_buffer.h
size_t xStreamBufferSendFromISR( StreamBufferHandle_t xStreamBuffer,
                                 const void *pvTxData,
                                 size_t xDataLengthBytes,
Interrupt safe version of the API function that sends a stream of bytes to the stream buffer.
Use xStreamBufferSend() to write to a stream buffer from a task. Use xStreamBufferSendFromISR() to write to a stream buffer from an interrupt service routine (ISR).
xStreamBuffer   The handle of the stream buffer to which a stream is being sent.
pvTxData   A pointer to the buffer that holds the bytes to be copied into the stream buffer.
xDataLengthBytes   The maximum number of bytes to copy from pvTxData into the stream buffer.
pxHigherPriorityTaskWoken   (This is an optional parameter that can be set to NULL.) It is possible that a stream buffer will have a task blocked on it waiting for data. Calling xStreamBufferSendFromISR() can make data available, and so cause a task that was waiting for data to leave the Blocked state. If calling xStreamBufferSendFromISR() causes a task to leave the Blocked state, and the unblocked task has a priority higher than the currently executing task (the task that was interrupted), then, internally, xStreamBufferSendFromISR() will set *pxHigherPriorityTaskWoken to pdTRUE. If xStreamBufferSendFromISR() sets this value to pdTRUE, then normally a context switch should be performed before the interrupt is exited. This will ensure that the interrupt returns directly to the highest priority Ready state task. *pxHigherPriorityTaskWoken should be set to pdFALSE before it is passed into the function. See the example code below for an example.
The number of bytes written to the stream buffer. If a task times out before it can write all xDataLengthBytes into the buffer it will still write as many bytes as possible.
size_t xBytesSent;
    /* Attempt to send the string to the stream buffer. */
    xBytesSent = xStreamBufferSendFromISR( xStreamBuffer,
                                           ( void * ) pcStringToSend,
                                           strlen( pcStringToSend ),
                                           &xHigherPriorityTaskWoken );
        /* There was not enough free space in the stream buffer for the entire
        string to be written, ut xBytesSent bytes were written. */
    xStreamBufferSendFromISR() then a task that has a priority above the
