xTaskCreateRestricted
[FreeRTOS-MPU Specific]
task. h
BaseType_t xTaskCreateRestricted(
                            TaskParameters_t *pxTaskDefinition,
xTaskCreateRestricted() is intended for use with FreeRTOS-MPU, the demo applications for which contain comprehensive and documented examples of xTaskCreateRestricted() being used.
pxTaskDefinition Pointer to a structure that defines the task. The structure is described on this page.
Tasks that include MPU support require even more parameters to create than those that don't. Passing each parameter to xTaskCreateRestricted() individually would be unwieldy so instead the structure TaskParameters_t is used to allow the parameters to be configured statically at compile time. The structure is defined in task.h as:
    TaskFunction_t pvTaskCode;
    unsigned short usStackDepth;
    void *pvParameters;
    UBaseType_t uxPriority;
} TaskParameters_t;
typedef struct xMEMORY_REGION
    void *pvBaseAddress;
    unsigned long ulParameters;
} MemoryRegion_t;
  • pvTaskCode to uxPriority
    These members are exactly the same as the parameters to xTaskCreate() of the same name. In particular uxPriority is used to set both the priority of the task and the mode in which the task will execute. For example, to create a User mode task at priority 2 simply set uxPriority to 2, to create a Privileged mode task at priority 2 set uxPriority to ( 2 | portPRIVILEGE_BIT ).
  • puxStackBuffer
    Each time a task is switched in the MPU is dynamically re-configured to define a region that provides the task read and write access to its own stack. MPU regions must meet a number of constraints - in particular, the size and alignment of each region must both be equal to the same power of two value.
    Standard FreeRTOS ports use pvPortMalloc() to allocate a new stacks each time a task is created. Providing a pvPortMalloc() implementation that took care of the MPU data alignment requirements would be possible but would also be complex and inefficient in its RAM usage. To remove the need for this complexity FreeRTOS-MPU allows stacks to be declared statically at compile time. This allows the alignment to be managed using compiler extensions and RAM usage efficiency to be managed by the linker. For example, if using GCC a stack could be declared and correctly aligned using the following code:
    puxStackBuffer would normally be set to the address of the statically declared stack. As an alternative puxStackBuffer can be set to NULL - in which case pvPortMallocAligned() will be called to allocate the task stack and it is the application writers responsibility to provide an implementation of pvPortMallocAligned() that meets the alignment requirements of the MPU.
  • xMemoryRegions
        portMPU_REGION_READ_WRITE
        portMPU_REGION_READ_ONLY
        portMPU_REGION_EXECUTE_NEVER
/* Declare the stack that will be used by the task. The stack alignment must match its size and be a power of 2, so if 128 words are reserved for the stack then it must be aligned to ( 128 * 4 ) bytes. This example used GCC syntax. */ static portSTACK_TYPE xTaskStack[ 128 ] __attribute__((aligned(128*4))); /* Declare an array that will be accessed by the task. The task should only be able to read from the array, and not write to it. */ char cReadOnlyArray[ 512 ] __attribute__((aligned(512))); /* Fill in a TaskParameters_t structure to define the task - this is the structure passed to the xTaskCreateRestricted() function. */ static const TaskParameters_t xTaskDefinition = { vTaskFunction, /* pvTaskCode */ "A task", /* pcName */ 128, /* usStackDepth - defined in words, not bytes. */ NULL, /* pvParameters */ 1, /* uxPriority - priority 1, start in User mode. */ xTaskStack, /* puxStackBuffer - the array to use as the task stack. */ /* xRegions - In this case only one of the three user definable regions is actually used. The parameters are used to set the region to read only. */ { /* Base address Length Parameters */ { cReadOnlyArray, mainREAD_ONLY_ALIGN_SIZE, portMPU_REGION_READ_ONLY }, { 0, 0, 0 }, { 0, 0, 0 }, } }; void main( void ) { /* Create the task defined by xTaskDefinition. NULL is used as the second parameter as a task handle is not required. */ xTaskCreateRestricted( &xTaskDefinition, NULL ); /* Start the RTOS scheduler. */ vTaskStartScheduler(); /* Should not reach here! */ }
