FreeRTOS SMP:
Embedded World track keynote:
xTimerPendFunctionCall()
 BaseType_t xTimerPendFunctionCall(
                            void *pvParameter1,
                            uint32_t ulParameter2,
                            TickType_t xTicksToWait );
Used to pend the execution of a function to the RTOS daemon task (the timer service task, hence this function is pre-fixed with 'Timer').
Functions that can be deferred to the RTOS daemon task must have the following prototype:
The pvParameter1 and ulParameter2 are provided for use by the application code.
INCLUDE_xTimerPendFunctionCall() and configUSE_TIMERS must both be set to 1 for xTimerPendFunctionCall() to be available.
xFunctionToPend   The function to execute from the timer service/ daemon task. The function must conform to the PendedFunction_t prototype as shown above.
pvParameter1   The value of the callback function's first parameter. The parameter has a void * type to allow it to be used to pass any type. For example, integer types can be cast to a void *, or the void * can be used to point to a structure.
ulParameter2   The value of the callback function's second parameter.
xTicksToWait   Calling this function will result in a message being sent to the timer daemon task on a queue. xTicksToWait is the amount of time the calling task should remain in the Blocked state (so not using any processing time) for space to become available on the timer queue if the queue is found to be full. The length of the queue is set by the value of configTIMER_QUEUE_LENGTH in FreeRTOSConfig.h.
pdPASS is returned if the message was successfully sent to the RTOS timer daemon task, otherwise pdFALSE is returned.
