SUPPORT
FreeRTOS LTS:
Homepage | FAQ
FreeRTOS FAQ - AWS IoT Reference Integrations
How can I add my microcontroller-based board to the FreeRTOS.org IoT Reference Integrations page?
How do I get started with FreeRTOS LTS libraries, if I want to use AWS IoT features?
To list your board in the AWS IoT Reference Integrations page, follow the qualification process listed in the AWS Device Qualification Program. In this program, you will need to validate your FreeRTOS port, submit the validation results, and list your board in the AWS Partner Device Catalog. Once qualified, your board will be listed in the FreeTOS.org IoT Reference Integrations page.
You can build your project from scratch by cloning GitHub repositories of individual libraries, or start from IoT reference integrations in FreeRTOS.org and update individual libraries to FreeRTOS LTS libraries. Some IoT reference integrations have been pre-integrated with FreeRTOS LTS libraries, and you can identify them by the tag, “Uses FreeRTOS YYYYMM.XX LTS libraries”. Once you make a selection, it will take you to the AWS Partner Device Catalog, where you can review a list of LTS libraries used in the reference integration, and a getting started guide for specific MCU-based boards.
