message_buffer.h
MessageBufferHandle_t xMessageBufferCreateStatic(
size_t xBufferSizeBytes,
uint8_t *pucMessageBufferStorageArea,
StaticMessageBuffer_t *pxStaticMessageBuffer );
Creates a new message buffer using statically allocated memory. See
xMessageBufferCreate() for a version that
uses dynamically allocated memory.
must be set to 1 in FreeRTOSConfig.h for xMessageBufferCreateStatic() to be available.
xBufferSizeBytes
The size, in bytes, of the buffer pointed to by the
pucMessageBufferStorageArea parameter. When a message is written to the
message buffer an additional sizeof( size_t ) bytes are also written to store
the message's length. sizeof( size_t ) is typically 4 bytes on a 32-bit
architecture, so on most 32-bit architecture a 10 byte message will take up
14 bytes of message buffer space. The maximum number of bytes that can be
stored in the message buffer is actually (xBufferSizeBytes - 1).
Must point to a uint8_t array that is at least
xBufferSizeBytes + 1 big. This is the array to which messages
are copied when they are written to the message buffer.
Must point to a variable of type StaticMessageBuffer_t, which
will be used to hold the message buffer's data structure.
If the message buffer is created successfully then a handle to the
created message buffer is returned. If either pucMessageBufferStorageArea or
pxStaticMessageBuffer are NULL then NULL is returned.
/* Used to dimension the array used to hold the messages. The available space
will actually be one less than this, so 999. */
/* Defines the memory that will actually hold the messages within the message
buffer. Should be one more than the value passed in the xBufferSizeBytes
parameter. */
static uint8_t ucStorageBuffer[ STORAGE_SIZE_BYTES ];
/* The variable used to hold the message buffer structure. */
StaticMessageBuffer_t xMessageBufferStruct;
void MyFunction( void )
xMessageBuffer = xMessageBufferCreateStatic( sizeof( ucStoragegBuffer ),
ucBufferStorage,
&xMessageBufferStruct );
/* As neither the pucMessageBufferStorageArea or pxStaticMessageBuffer
parameters were NULL, xMessageBuffer will not be NULL, and can be used to
reference the created message buffer in other message buffer API calls. */
/* Other code that uses the message buffer can go here. */
