xMessageBufferReceive()
[RTOS Message Buffer API]
message_buffer.h
size_t xMessageBufferReceive( MessageBufferHandle_t xMessageBuffer,
                              void *pvRxData,
                              size_t xBufferLengthBytes,
                              TickType_t xTicksToWait );
Receives a discrete message from an RTOS message buffer. Messages can be of variable length and are copied out of the buffer.
pvRxData   A pointer to the buffer into which the received message is to be copied.
xTicksToWait   The maximum amount of time the task should remain in the Blocked state to wait for a message, should the message buffer be empty when xMessageBufferReceive() was called. xMessageBufferReceive() will return immediately if xTicksToWait is zero and the message buffer is empty. The block time is specified in tick periods, so the absolute time it represents is dependent on the tick frequency. The macro pdMS_TO_TICKS() can be used to convert a time specified in milliseconds into a time specified in ticks. Setting xTicksToWait to portMAX_DELAY will cause the task to wait indefinitely (without timing out), provided INCLUDE_vTaskSuspend is set to 1 in FreeRTOSConfig.h. Tasks do not use any CPU time when they are in the Blocked state.
The length, in bytes, of the message read from the message buffer, if any. If xMessageBufferReceive() times out before a message became available then zero is returned. If the length of the message is greater than xBufferLengthBytes then the message will be left in the message buffer and zero is returned.
void vAFunction( MessageBuffer_t xMessageBuffer )
uint8_t ucRxData[ 20 ];
size_t xReceivedBytes;
    /* Receive the next message from the message buffer.  Wait in the Blocked
    state (so not using any CPU processing time) for a maximum of 100ms for
    a message to become available. */
    xReceivedBytes = xMessageBufferReceive( xMessageBuffer,
                                            ( void * ) ucRxData,
                                            sizeof( ucRxData ),
                                            xBlockTime );
    if( xReceivedBytes > 0 )
        the message here.... */
