xStreamBufferReceiveFromISR()
[RTOS Stream Buffer API]
stream_buffer.h
size_t xStreamBufferReceiveFromISR( StreamBufferHandle_t xStreamBuffer,
                                    void *pvRxData,
                                    size_t xBufferLengthBytes,
An interrupt safe version of the API function that receives bytes from a stream buffer.
xStreamBuffer   The handle of the stream buffer from which bytes are to be received.
pvRxData   A pointer to the buffer into which the received bytes will be copied.
xBufferLengthBytes   The length of the buffer pointed to by the pvRxData parameter. This sets the maximum number of bytes to receive in one call. xStreamBufferReceive will return as many bytes as possible up to a maximum set by xBufferLengthBytes.
pxHigherPriorityTaskWoken   It is possible that a stream buffer will have a task blocked on it waiting for space to become available. Calling xStreamBufferReceiveFromISR() can make space available, and so cause a task that is waiting for space to leave the Blocked state. If calling xStreamBufferReceiveFromISR() causes a task to leave the Blocked state, and the unblocked task has a priority higher than the currently executing task (the task that was interrupted), then, internally, xStreamBufferReceiveFromISR() will set *pxHigherPriorityTaskWoken to pdTRUE. If xStreamBufferReceiveFromISR() sets this value to pdTRUE, then normally a context switch should be performed before the interrupt is exited. That will ensure the interrupt returns directly to the highest priority Ready state task. *pxHigherPriorityTaskWoken should be set to pdFALSE before it is passed into the function. See the code example below for an example.
The number of bytes read from the stream buffer, if any.
StreamBuffer_t xStreamBuffer;
uint8_t ucRxData[ 20 ];
size_t xReceivedBytes;
    /* Receive the next stream from the stream buffer. */
    xReceivedBytes = xStreamBufferReceiveFromISR( xStreamBuffer,
                                                  ( void * ) ucRxData,
                                                  sizeof( ucRxData ),
                                                  &xHigherPriorityTaskWoken );
    if( xReceivedBytes > 0 )
        /* ucRxData contains xReceivedBytes read from the stream buffer.
        Process the stream here.... */
    xStreamBufferReceiveFromISR() then a task that has a priority above the
