xSemaphoreCreateBinary
[Semaphores]
semphr. h
SemaphoreHandle_t xSemaphoreCreateBinary( void );
Creates a binary semaphore, and returns a handle by which the semaphore can be referenced. configSUPPORT_DYNAMIC_ALLOCATION must be set to 1 in FreeRTOSConfig.h, or left undefined (in which case it will default to 1), for this RTOS API function to be available.
Return values:
NULL   The semaphore could not be created because there was insufficient FreeRTOS heap available.
SemaphoreHandle_t xSemaphore;
    /* Attempt to create a semaphore. */
    xSemaphore = xSemaphoreCreateBinary();
    if( xSemaphore == NULL )
        /* There was insufficient FreeRTOS heap available for the semaphore to
        be created successfully. */
        /* The semaphore can now be used. Its handle is stored in the
        xSemahore variable.  Calling xSemaphoreTake() on the semaphore here
        will fail until the semaphore has first been given. */
