FreeRTOS SMP:
Embedded World track keynote:
xQueueSendToBackFromISR
[Queue Management]
queue.h
BaseType_t xQueueSendToBackFromISR ( QueueHandle_t xQueue, const void *pvItemToQueue, BaseType_t *pxHigherPriorityTaskWoken );
Post an item to the back of a queue. It is safe to use this function from within an interrupt service routine.
Items are queued by copy not reference so it is preferable to only queue small items, especially when called from an ISR.
pxHigherPriorityTaskWoken xQueueSendTobackFromISR() will set *pxHigherPriorityTaskWoken to pdTRUE if sending to the queue caused a task to unblock, and the unblocked task has a priority higher than the currently running task. If xQueueSendToBackFromISR() sets this value to pdTRUE then a context switch should be requested before the interrupt is exited.
pdPASS if sending to the queue was successful, otherwise errQUEUE_FULL.
Example usage for buffered IO (where the ISR can obtain more than one value per call):
void vBufferISR( void ) { char cIn; BaseType_t xHigherPriorityTaskWoken; /* We have not woken a task at the start of the ISR. */ xHigherPriorityTaskWoken = pdFALSE; /* Loop until the buffer is empty. */ do { /* Obtain a byte from the buffer. */ cIn = portINPUT_BYTE( RX_REGISTER_ADDRESS ); /* Post the byte. */ xQueueSendToBackFromISR( xRxQueue, &cIn, &xHigherPriorityTaskWoken ); } while( portINPUT_BYTE( BUFFER_COUNT ) ); /* Now the buffer is empty we can switch context if necessary. */ if( xHigherPriorityTaskWoken ) { /* Actual macro used here is port specific. */ taskYIELD_FROM_ISR (); } }
