FreeRTOS SMP:
Embedded World track keynote:
xSemaphoreCreateBinaryStatic
[Semaphores]
semphr. h
SemaphoreHandle_t xSemaphoreCreateBinaryStatic(
                          StaticSemaphore_t *pxSemaphoreBuffer );
Creates a binary semaphore, and returns a handle by which the semaphore can be referenced. configSUPPORT_STATIC_ALLOCATION must be set to 1 in FreeRTOSConfig.h for this RTOS API function to be available.
pxSemaphoreBuffer   Must point to a variable of type StaticSemaphore_t, which will be used to hold the semaphore's state.
Return values:
NULL   The semaphore could not be created because pxSemaphoreBuffer was NULL.
 StaticSemaphore_t xSemaphoreBuffer;
    /* Create a binary semaphore without using any dynamic memory
    allocation.  The semaphore's data structures will be saved into
    the xSemaphoreBuffer variable. */
    xSemaphore = xSemaphoreCreateBinaryStatic( &xSemaphoreBuffer );
    /* The pxSemaphoreBuffer was not NULL, so it is expected that the
    handle will not be NULL. */
    configASSERT( xSemaphore );
